Help me stop my led lights falling down!! Argh!
Discussion in 'General Chat' started by smallclanger, Apr 6, 2016.
Tags:
  1. smallclanger
    smallclanger
    May 9, 2007
    2,247
    Southampton
    +460
    We had a new kitchen a few years ago and after a while one of the lights fell off so I stuck it back with double sided sticky pads, it stayed for a while then fell off again, now another one wont stay:
    Any suggestions welcome, there doesn't seem to be a better way to fix them ie with screws etc.
  2. Bubblin
    Bubblin
    Nov 12, 2006
    1,282
    116
    Medway
    +661
    It's the heat and grease that does this, looks like there are two screw holes in the light,modes the fitting not twist to drop the unit out to enable it to be screwed up?
  3. smallclanger
    smallclanger
    May 9, 2007
    2,247
    Southampton
    +460
    Actually I think you are right, looks like the kitchen fitters just stuck them up but the led part unclips so I can put a couple of screws up - at least I can when I recover from my wrist surgery..
  4. Sonic67
    Sonic67
    Sep 14, 2006
    40,942
    11
    167
    Home
    +18,321
  5. smallclanger
    smallclanger
    May 9, 2007
    2,247
    Southampton
    +460
    Sorted the two usual suspects, two small screws in each doing the job now.
