Help me spend the money!
Discussion in 'Arcam Owners' Forum' started by calsam, Aug 21, 2005.
Tags:
  1. calsam
    calsam
    Jul 16, 2005
    12
    Have around £8,000 for a full home cinema system including lcd/plasma, dvd player, amplifier/reveiver and speakers. Anyone got any suggestions as a starting point. CD is the priority though still want decent movie sound, so was thinking about Arcam...
  2. endora
    endora
    Jul 6, 2004
    261
    Ok, give me a £1,000 and I will help you ;)
  3. RumNYC
    RumNYC
    May 31, 2005
    247
    Tokyo
    +9
    Simple...
    1) Speakers: B&W 804S or 803S
    2) Arcam AVR300 or AVP700+either P1000 or FMJ P35
    3) Arcam CD36 for CD
    4) Good interconnects and power cables/conditioners.
  4. Hifi addict
    Hifi addict
    and then you still need a center, rearspeakers, speakercable and a plasma......
  5. Audionyx
    Audionyx
    Dec 10, 2002
    695
    East Yorkie Porky
    +28
    Simple!
    Arcam DV79 £1000
    Arcam AV700 £1400
    Arcam P1000 £1600
    5 * PMC DB1+ £1600
    Panasonic PW7 with SCART/Componenet + Stand ~ £1600
    SVS PB12-Plus Subwoofer - £800
    £8000 for a stonking system - the dealer will undoubtedly throw in all the cables with that £4k Arcam purchase!
    Just my recommendation if starting from scratch!
  6. Hifi addict
    Hifi addict
    if you state that CD is a priority for you, you have to ask yourself if you want a dedicated CD player or not. You could also go for the DV27A or DV29 which both have very good DVD playback and a good CD playback.
    You have to determine your starting point and work from there. If HT is your thing then you will have a different point of choise then when you go for stereo with a HT touch.
  7. Palu
    Palu
    Well, my HT setup is (prices in Euro):
    I would suggest a Denon 2910 DVD (€ 699), a Hitachi PJ TX 100 with stunning picture(really cheap now € 1200) and use the DVI or HDMI exit and a BEAMAX 16:9 format screen (€279).
    For the sound I would suggest: Cambridge 640 AZUR (€ 600) and a Mission M Cube (€ 1000). Alternative: Final 80i ELS surround set. (www.finalsound.com) € 1500.
    If you buy this you only need £ 2900 or £ 3400.
  8. ufitsy
    ufitsy
    Aug 18, 2004
    3,237
    103
    Midlands
    +341
    Buy second-hand off these forums & get 16-20 k's worth of kit & lose alot less when you move it on.
  9. mjn
    mjn
    May 24, 2001
    21,881
    Herts, England
    +9,574
    Personally, i'd up your budget a little........
