Help me spend my money please
Discussion in 'Projectors, Screens & Video Processors' started by rich1231, Apr 27, 2005.
  1. rich1231
    rich1231
    Sep 3, 2004
    122
    Hi all,
    I sold my Lounge TV on new years eve during a party. It was supposed to spur me on to get a plasma for the lounge wall. (Already got one in the bedroom, so im sold on them)
    But now Im used to not having a TV in the lounge, I have thought about getting a projector instead for films, sports etc.
    I had a demo of a Sim20 20H today and I was impressed. The price was approx 3k for the pj.
    I would like the pj, cables, mount and screen to come in at 5k or less.
    The room is large about 42' by 25' . I would also like to embed the screen in the ceiling if possible. Also the projector should be HDMI-HDCP compatible.
    Really would welcome anyones thoughts..
    Rich
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    If you've see the Sim2 and know you don't suffer from 'rainbows' then for just a bit more you could get an Optoma H78 which is hidef resolution which would be preferable IMX if you want to use a larger screen, say 80" or more.
  3. rich1231
    rich1231
    Sep 3, 2004
    122
    Kragorn,
    the Sim2 seems to have compatibility with all the appropriate Hidef display types. I know its resolution is less that the Optoma. But couldnt get a demo of that unit.
    Using Hidef material, how much difference would there be between the 2 pj's? has anyone compared them?
    rich
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    My comment about resolution isn't so much concerned with how well either would render a hidef source, downscaling by the lower res. projector wiuld still produce a good quality image.
    I was looking at it from the image itself. I had a Sharp Z200E before the Optoma, projecting on to a 92" screen. The Sharp was 1024x576 and although the picture was very good in terms of colour, black depth etc., on that size screen viewed from 1.5 screen width distance the pixellation was noticeable and over time I found annoying. The H77's highre resolution solved that for me.
  5. rich1231
    rich1231
    Sep 3, 2004
    122
    Ok, thanks for that, it sort of makes sense.
    How about brightness. My lounge isnt blacked out. So For twilight viewing which is the brighter?
    Rich
  6. rich1231
    rich1231
    Sep 3, 2004
    122
    Right,
    Pj's I have now seen demo'd are:
    Sim2 20H (looked great, but Im concerned that it doesnt have the resolution of the 30H or Themescene H78)
    Sharp XV-Z10000 ( looked great as well, only doubt i have is it uses an older chipset than the Sim2)
    Others I am considering:
    Sharp XV-Z2000 the reviews like it but I have noticed on pictures it doesnt have a 12v output for projector switching, which to me now I ahve looked into this is important. Or is there another way to switch them.
    The sim2 30h, looks great but is just a bit out of my budget.
    Themescen H78, seems to have all boxes ticked for features but I cant find anyone close to demo it. Im in Southend in Essex.
    The more i read the more complex its getting for me.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,556
    The Borders
    +3,026
    rich1231
    For 'twilight' viewing the H78 is 'bright enough' - though you cant beat using any projector in Dark or near Dark conditions.
    Embedding your Screen in your ceiling is going to stretch your budget if you want a Screen that's designed for 'In-ceiling' installations - otherwise you'd have to adapt an 'On-wall' unit; which are much less costly.
    I take it you have a separate budget for the source and audio kit.
    Best regards
    Joe
  8. rich1231
    rich1231
    Sep 3, 2004
    122
    Thanks Joe,
    Source and audio kit are already sorted thanks.
    In ceiling is now a no no as well, I have checked the ceiling out and the floorboard supports for the floor above are going the wrong way.
    Regards
    Richard
  9. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    My mate bought an electric screen from nexnix cut hole in ceiling and mounted screen on beam, then re-plasterboarded/plastered up to a small 1" slot... it looks very neat and works well... he didnt get remote but uses trigger from his AE700 to drop screen. As said this a much cheaper way of doing it than buying dedicated in-ceiling mount screen.
    Of course if your beams are the wrong way its a bit of a non-starter!!!
  10. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    2 mins too late with my post!!! Shame about the beams!
    EDIT... Have you looked at Screenplay 7205? This would be in your budget and has the 1280x720 resolution.
  11. rich1231
    rich1231
    Sep 3, 2004
    122
    Guido, not included the screenplay in the list yet..
    I'll take a look thanks!
    Rich
  12. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    SP7205 was a £5k pj until recently, but is around 3.5 now.
    http://www.infocushome.com/emea/eng/products/screenplay/sp7205.asp
    Happy choosing... wish I had had £5k budget! :cool:
    Managed to do the whole lot for £2500 inc source, audio, cables, pj, screen etc with eBay and bargaining and serious shopping around!
    Not sure where you'd get a demo of 7205 in Southend though.... is there a Sevenoaks HiFi near you? My local one was very helpful for demos.
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,556
    The Borders
    +3,026
    Hello both
    I've 'seen' a few Screens that are Load Bearing - its amazing what folk get up to after a trip to B&Q :)
    Lots of Drop Down screens now have 'non agricultural' housings - Beamax do a nice Aluminium job that's had the thumbs up from a few 'sceptical' customers significant others!!!
    Have you considered a custom 'frameless' fixed screen - if your wall colours not to dissimilar to the screen fabric this can work well.
    Best regards
    Joe
  14. rich1231
    rich1231
    Sep 3, 2004
    122
    Cheers Joe,
    I cant take over a wall, the screen is going to come down 2 feet in front of if as there is shelving in the way.
    Getting a complete blackout is going to be really difficult also, as I have go a skylight in the roof in a stairwell about 35feet from the inteded location. I can blackout all the windows but the skylight will be really tough...
    ta
    Rich
