Help me spend £1000 on new set-up
Discussion in 'Home Cinema Speakers' started by P13TR0, Aug 8, 2004.
  1. P13TR0
    P13TR0
    Hi... I am about to move house and am looking at an AV set-up. I want 5.1 with the option to upgrade to 6.1 when I have the money. I have pretty much made a descision on my plasma... Panasonic TH-42PWD6.
    I was looking at the Denon 770SD surround package, but just wanted to check what I could do with £1000 to get better results.
    I would like Progressive scan DVD player, 6.1 receiver, and to start with two fronts, two rears, a centre and a sub if necessary.
    This system will be used for home cinema, but I would like it to be good enough to play audio CD's. I realise that £1000 isn't a huge amount to play with, so would you suggest to go down the all in system route and upgrade to seperates when I have the money?
    Thanks for your thoughts!
