Help me spec a small pc :)
Discussion in 'PC Gaming & Rigs' started by mozza54, Mar 2, 2013.
  1. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    I've spent a few hours at this today and I'm a little stuck as to what would be a decent build. I started out looking at the alienware x51 and after a few of you suggest I could build my own cheaper I had a look about and found a few good deals.
    I basically want to be able to run Crysis 3 and have something I could get a couple of years out of, I tend to use 1080p screen so don't need silly resolutions. I've been looking at itx setup as is for a living room and wanted to spend about 600ish At the most.
    Looking forward to your recommendations
  2. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,850
    127.0.0.1
    +7,663
    I'll spec something up later on but it'll basically be along the lines of this pre-built: CCL Elite Eyas Mini Gaming PC - - CCL Computers
    Dropping the SSD and/or tweaking it slightly will make it fit into your budget. For the form factor it's impressive performance!
  3. jjgreenwood
    jjgreenwood
    Nov 20, 2009
    3,766
    137
    The depths of hell
    +1,019
  4. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,850
    127.0.0.1
    +7,663
  5. PocketBunny
    PocketBunny
    Oct 5, 2010
    3,283
    +680
    It's the pc gaming forum ash. You know the budget amount is there to blown ;)
  6. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
  7. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,850
    127.0.0.1
    +7,663
    Not when it's overpriced. Compare the Scan rig to the CCL one. Slightly faster CPU and nicer case but with a slower graphics card and no SSD.
  8. jjgreenwood
    jjgreenwood
    Nov 20, 2009
    3,766
    137
    The depths of hell
    +1,019
  9. jjgreenwood
    jjgreenwood
    Nov 20, 2009
    3,766
    137
    The depths of hell
    +1,019
  10. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
  11. FelixLeiter
    FelixLeiter
    Mar 11, 2007
    1,041
    Solihull
    +199
    The 660ti is the better card but do yourself a favour, buy an AMD 7870 tahiti LE and save £50. Ive just traded my 660ti for this card and its getting better benchmark scores albeit after some overclocking.
  12. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    After quite a bit of umming and ahhing, I ended up with the X51.. Might seem a bit daft but Ive got it for just over £650 which considering what you get aint half bad. When I specced up all the parts in the x51, doing it myself wasnt making that much of a saving and Ive still got the option there for a better CPU and GPU.
    That'll also go down a bit as I got it through quidco who were doing 11% cashback.
    Appreciate all the help though guys. :thumbsup:
  13. samtman
    samtman
    Aug 22, 2009
    1,300
    2
    Adlington
    +441
    I got the x51 it's a good machine. The only problem I can see is if feel the need to update anything with the small case and the 330w power. I am happy with mine and think you will be too.
  14. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    Did it take long to turn up? Theyre saying anything up to 3 weeks, this is gonna kill me :facepalm:
  15. samtman
    samtman
    Aug 22, 2009
    1,300
    2
    Adlington
    +441
    Mine took 5 days but I got a refurb from dell outlet.
  16. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    Stupid bloody Dell, after 2 days of the worst customer services ever, my orders ended up being cancelled.. not impressed.
    Anyhew, I priced this up on ebuyer, Ive got a spare 1tb hd and os so doesnt seem to bad.
    Hopefully the 7870 will be a good choice (seems decent enough)
