Help me setup my 5.1 setup !
Discussion in 'AV Receivers & Amplifiers' started by MrLOL, Sep 19, 2007.
  1. MrLOL
    MrLOL
    Nov 13, 2005
    403
    28
    Wakefield
    +31
    ive got a Denon 1906 and some 5.1 surround speakers
    is it possible to configure the surround channels (the rear left + right) to be a bit louder ?
    ive ran the auto setup using the microphone and i can hear them fine, but only up close
    i could just turn the whole volume up, but that leads to the centre being too loud
    ive looked in the amp setup for this option but cant find it. Any suggestions as to where i should be looking ?
  2. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    You should be able to go into the speaker settings on the amp and set individualy the value in DB (decibels) you want for each speaker and the sub. Bit hit and miss the autosetup it had set my sub to +11db (way to high) upset the neighbours for days :D
  3. MrLOL
    MrLOL
    Nov 13, 2005
    403
    28
    Wakefield
    +31
    ive looked in speaker setup but couldnt find it
    any idea what the setting is called on a denon receiver ?
  4. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    Manually put your speaker distances in, and tell the receiver that the rears are further away from you than they actually are; that should pump them up a bit.
  5. MrLOL
    MrLOL
    Nov 13, 2005
    403
    28
    Wakefield
    +31
    that would make sense actually. I sit quite close to the surround speakers, so i suspect the auto setup is thinking they dont need to be very loud.
    Trouble is, i like my surround effects to be loud and overpowering, and i want to over rule the namby pamby setup routine.
    i hate the menus on my denon.what option am i looking for for the distance ?
  6. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    Sorry can only comment on my onkyo but Speaker distance is literally called that in mymanual and I've also got level calibration for setting the individual level's for each speaker. You might be best starting a new thread titled something along the lines of "denon 1906 need help with speaker settings"
  7. MrLOL
    MrLOL
    Nov 13, 2005
    403
    28
    Wakefield
    +31
    ive lost my manual (and the auto setup microphone) when we moved house
    they will be somewhere, but no idea where ..
    anyway,ive downloaded the manul and found the way to adjust the channel level
    does that sound about right ?
  8. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,919
    2
    The Fylde Coast
    +13,617
    That sounds right. Altering distance only affects the timing of the delivery of the signal to the channels, not the level of the channels.
    Don't take this personally, but, that's is so wrong on several levels for the Denon:
    (a) Denon has separate channels level adjustment
    (b) Adjusting distance will not affect the levels on any amp
    (c) Even if the levels did change on setting distance, a change in distance would incorrectly place the soundfield at the listening position.
