Help me regarding B&W.
Discussion in 'Home Cinema Speakers' started by zcaps57, Sep 30, 2001.
  1. zcaps57
    zcaps57
    Hi.
    Please help me.
    I'm thinking of buying a pair of main speakers and a center speaker in B&W CDM NT range.
    Suggested Retail Price for B&W CDM 7NT and 9NT are 1250 and 1800. (But I'm sure my local dealer will gimme some discount. Still... 550 GBP difference though. <img src="frown.gif" border="0"> )
    I have 2 options.
    BTW, DENON AVC-A1SE will be driving them.
    1. I go with CDM 7NT and CDM CNT, then I can buy a ASW500 subwoofer. (At the moment I'm using Yamaha YST-SW205 costs about 200.)<br />NB. B&W ASW500 sub costs about 350.
    2. I go with CDM 9NT and CDM CNT. have to keep using my Yamaha YST-SW205 sub.
    Which one should I go for ? (I know 9NT's are not only bigger, but has better mid-range driver than 7NT.)
    Oh, and I just read a news(?) in AVS Forums <a href="http://www.avsforum.com/ubb/Forum3/HTML/006526.html" target="_blank">http://www.avsforum.com/ubb/Forum3/HTML/006526.html</a> that B&W CDM NT range is marked down 30%, and the guy reckons that CDM NT range is being phased out. <br />Maybe replacements are on their way soon. <img src="frown.gif" border="0"> <br />Anyone heard this yet? <br />I mean if it's being replaced soon, should I wait ?
    Any info, comments would be much appreciated.
    Thanks!! <img src="smile.gif" border="0">
    [ 30-09-2001: Message edited by: Amaris ]</p>
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    No news of the B&W CDM NT range being phased out yet, but we didn't get told about the new 600 S3 until 3 days before the launch.
    Shouldn't think so yet though.
    If you go for the NT 7 or 9 then you'll find the ASW 500 a little disapopinting. You should be looking at the ASW1000 or 2500, maybe even the 4000. I would consider probably something like a MK V125, around £895.
    Don' t get the ASW500 at all with the CDM 7 or 9NT's, they will only really go with the syand mounting 1NT's.
    Enjoy.
  3. zcaps57
    zcaps57
    Thanks very much for your reply. <img src="smile.gif" border="0">
    As you told me I won't waste my money on ASW500 with CDM 7NT. <img src="smile.gif" border="0">
    By any chance, have you experienced both B&W CM4 and CDM 7NT ? If you have, could you share your thoughts on those speakers with me please?<br />(Basically, I would like your opinion for me to go from CM4 to CDM 7NT. reckon worth the extra cash?)
    Thanks again. <img src="smile.gif" border="0">
    [ 02-10-2001: Message edited by: Amaris ]</p>
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    We have stocked very little of either the CDM NT or CM ranges, there has been very little demand for hifi recently, as you might have guessed.
    However, I can assure you the NT7's are much better then the CM4's which are very dull sounding in comparison, and are not the best speakers in the price range.
    JohnG: I like the DS6, however some don't due to their Dolby Surround/THX origins which means they have limited frequency range. But this is not too noticeable with correct bass management.
  5. John G
    John G
    Nov 25, 2000
    308
    Matlock, Derbyshire
    +54
    Whilst on the topic of B&W does anyone know of any reviews or opinions on their DS6 Di-pole surround speaker?
    Thanks,John G
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    DS6: Given that the frequency range is also limited at the upper end (8kHz) and hence bass management would be of no use here I think they are not suitable for DD/DTS setups, as Retro says they originate from the times of DPL which is also limited in that regard. At least for GBP400 I think they are way too expensive though they may sound good, I won't argue with that ...
