Help me please
Discussion in 'Headphones, Earphones & Portable Music' started by jkrobs, Jun 21, 2005.
  1. jkrobs
    jkrobs
    Hi there, Im thinking to buy the Toshiba Gigabite F20...but Im not really sure if It will be enought space..basically, I have around 60 CD to burn onto the player and around 10 mp3 from my PC...but I want to know when i save Pictures on the player and albums arts stuff like that..does the player use space to put them on? Also Im thinking to Transfer each track from my CDs at the hightest Quality..I canot remeneber the bitrate? maybe 246? Anyway most of my songs are around 4 to 6 minutes a long..do you think with 20 gig I would have enought space..or should I get the F40? Is the F40 very fat? or not much Bigger than the F20? Sorry about this Im completely new to MP3 PLAYERS...also does the player have anti skip? Please help me..I wanna order it soon so it will arrive before you weekend..so i can put all my cd on it. Please reply. thanks
  2. jkrobs
    jkrobs
    :oops: Sorry..My typing is very bad :( I Hope you can read it.
  3. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    F20 should be fine and yes erm pictures and files do take up space on the player but you should be ok.
