Help Me Please
Discussion in 'Portable Disc & Media Players & Recorders' started by blueice, Jan 11, 2005.
  1. blueice
    blueice
    Hi guys,
    I have a DEH-P6300 CD pioneer stereo and i am looking to install it into my new renault megane. The magane has a steering wheel remote and am looking to find the lead which will let me connect to it.
    Have been to Haliford and they have said there is a lead but its going to cost me 40 pounds.
    Anyone know what the lead is and also if you know a good place to buy the lead near Peterborough or over the internet?!
    Thanks in advance for your help
    Blueice
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    ICE direct are in Peterborough (and the net) and have a really good reputation or www.mcs-direct.co.uk
  3. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    the only way to keep the functions you want is to get a pioneer IR stalk control adaptor. look on pioneers website for the part no but be warned these bits aren't cheap
  4. blueice
    blueice
    Well i know there is a proper lead that fits to the wheel remote and the pioneer but not sure what model it is or anything like that?!
  5. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    the two part no you need are cd-ra100+ and cd-rc103/4rn. to fit it you need to take off the top part of the dash which is done by removing the tweeter grilles and undoing one t20 torx screw either side. lift the dash upwards and it will unpop from its fixings. then remove the 3 t20 screws from around the clock. the cable you need is the red coloured plug on the back of the clock.
  6. blueice
    blueice
    And where would i get these and does everywhere fit them for you because aint into ruining my car would prefer the pro's to fit it for me!
  7. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    any pioneer dealer will be able to get these items and fit them for you but it is easy enough to do yourself
  8. diesel_uk
    diesel_uk
    the part is a interface. like a extention of the lead ()-----------()
