Help me please! Video lead question.....
Discussion in 'Cables & Switches' started by gilford, Aug 10, 2005.
  1. gilford
    gilford
    Feb 12, 2005
    7,564
    Welsh riviera........
    +1,008
    Hello again :hiya:
    When I bought my new Bose system it came iwth the yellow Video lead which I hooked up to the TV and everything was fine. The wire was a little shrt so I have been out and bought a longer one. Its a 5 meter gold plated one. Now every time I watch a film I have got 2 dark black bars on my screen?? Is this because of the lead? It was only a tenner so its no QED. Please help, its driving me crazy :eek: :rotfl:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    moved to cable forum
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,733
    The Borders
    +3,080
    gilford
    Try moving the long cable - it doest sound like its terribly well made and may be picking up interference from something its lying across or on.
    If the lines go away you can either live with it or consider a better quality (Note: not necessarily more expensive) cable.
    The 'Yellow' cable your using is carrying a 'Composite' video signal from your DVD player to your TV - this is the lowest quality video signal a manufacturer can provide; is there no other option on the DVD player?
    If the player has a SCART output socket you may find it offers you the ability to set the player to Output an RGB signal; if yes and your TV also has a SCART socket that is RGB enabled you'll get a much better picture if you install a decent SCART cable.
    Best regards
    Joe
  4. gilford
    gilford
    Feb 12, 2005
    7,564
    +1,008
    Thanks for the info. I have spoken to Bose today and they have said the same. The have told me to buy an S Video lead so I have ordered a QED one. I hope it sorts it! lol. I'll let you know how I get on. Cheers :) :)
