[HELP ME] PC PS3 Sky+HD Setting up 5.1 audio?
JohnM1983
davepuma
Does the card have spdif input? If it does, then you should be able to use an optical switch to switch between PS3 and Sky+ and then run an optical to 3.5mm toslink cable to the card.
Your best bet is to post in the sound cards forum though
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
