craigizmo2k2
Hi guys.
Bagged a Sanyo PLC-XP18E HD projector off ebay for 225 quid.
The seller mentioned some filters were removed due to scorching internally to the projector.
The result is this image:
I've rang around a few places and explained the problem and that the brightness/contrast settings are right down, and one guy said it sounds like its the polarisers that have been taken out, and once replaced will fix the problem.
Another issue becuase of this is, even though the projector is in 16:9 mode, you can still see light being projected where there should be no image at all.
Anyone able to shed any light on this?? The image is currently so bright that on dark scenes in movies you can not see ANY detail.
I'm prepared to spend quite a bit on this to get it repaired as it is a really well specced projector and I got it cheaply.
Any help appreciated!
