help me out
Discussion in 'Home Cinema Speakers' started by jelly, Oct 17, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    if i was to buy a set of mission m71i £49.99 is there any way that i can have them as rear surrounds in a 7.1 set up as well as using them as stereo speakers for music
  2. SanPedro
    SanPedro
    Jan 11, 2001
    4,526
    +510
    Jelly
    Is that from separate amps then?
    Don't see why not. Just run 2 sets of wires into them I believe. (but I stand to be corrected on this)
    However, is there any particular reason that you you're not using your front speakers for stereo duties from your AV amp??? Just seems a bit odd to have rears as stereo speakers when i'm assuming all your chairs etc. are pointing at your screen and not at your rear speakers.
    Chris
  3. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    Well thing is that the mission fs1 speakers don't sound that good music wise, that's why i thought a pair of speakers designed for stereo would be good. i don't want to put them on the front 'cause they won't match the fs1's :blush: :devil: :hiya:
  4. SanPedro
    SanPedro
    Jan 11, 2001
    4,526
    +510
    See what you mean.
    Are you planning to run them from another amp though? Don't know how you would get stereo through a set of surround speakers from an AV amp. Only going off my own experience with a cheapie Sherwood, there is no way I can set the rear surrounds to stereo, only the fronts.
    Maybe someone else can enlighten...
    Chris
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    You could in a wierd way with an HK AVR4550 the 7.1 rears are also a Zone 2 outlets not sure how easy it will be to swicth functions though.
    Get proper fronts and use the FS1 as rears it would look daft with 5 FS1 and 2 M71i anyway! Better of with some similar (looking) fronts for Music use and use the 5FS1 for suround units only.
    Canton doe some nice silver units might want to replace the centre with a canton too for a better Tonal match!
    Look here. http://www.canton.de/www/index.php4?pg_id=14,30,cd100,2,en
    and one of these:http://www.canton.de/www/index.php4?pg_id=14,30,cd50,2,en
  6. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    It is not a good idea to connect 2 amplifiers to the same speaker terminals. Ever.
    Please don't try it.
