Help me make a decision which one should i go for
kgrz283
Need to choose a projector.
My requirements.
I will be projecting on a plain white wall painted with dulux light and space absolute white paint, the projector will be approximately 15ft away from the wall projecting a 130” screen and will be mainly used for movies.
Which one should I go for now for optoma i've read about the rainbow effect which is a little off putting, i also would like one where the lamp replacement doesn't cost ££££.
Choice is below and i would like to purchase from richer sounds as they offer a 6 year warranty.
Optoma HD145X
Optoma HD28e
Optoma HD29He
Benq TH585
EPSON EH-TW740
Your expert advice appreciated.
thanks.
dunxd
I have an Optoma HD143X which was available from Richer Sounds last year - it looks to be very similar with the newer model being a bit brighter, which never hurts. It is a sound projector - perhaps a little noisy but at this price point you won't find much quieter.
I experienced the rainbow effect with my first DLP projector, and it annoyed me initially. A few months in and I barely noticed it - I now have to look specifically for it. It didn't turn out to be a problem for me - your mileage may vary of course.
+1 for Richer Sounds and their 6 year extended warranty included in the price. The bulb may well go, and if it does don't replace it with a cheapo one from Ebay or Amazon - false economy. You should get a few years out of the original bulb.
I can't comment on the other projectors much beyond comparing the specs, which I am sure you already did. I would say not to overthink it but get on with buying it and enjoying it sooner.
kgrz283
Specs are as below.
Benq TH585
Brightness 3500
Contrast Ratio 10,000:1
Lens Shift Digital verison only
Pixel Resolution 1920 x 1080
Throw Ratio 1.50 ~ 1.65
Lumens 3000 +
Display 200/300 (Optimised picture quality/Lower quality picture)
Fan Noise 29/35 (Eco/Normal)
EPSON EH-TW740
Brightness 3300
Contrast Ratio 16,000:1
Throw Ratio 1.21 - 1.63:1
Lumens 3000 +
Fan Noise 28/37dB (Eco/Normal)
Optoma HD145X
Brightness 3400
Contrast Ratio 25,000:1
Throw Ratio 1.47:1 - 1.62:1
Lumens 3000 +
Fan Noise 26dB/28dB (Eco/Max)
Optoma HD28e
Brightness 3800
Contrast Ratio 30,000:1
Lumens 3000 +
Optoma HD29He
Brightness 3600
Contrast Ratio 50,000:1
HDR Yes
Lumens 3000 +
thanks.
