Question Help me identify the best value 55" TV
Discussion in 'What Is The Best TV For You?' started by joeyburgerza, Aug 25, 2018.
  1. joeyburgerza
    joeyburgerza
    Aug 25, 2018
    2
    4
    South Africa
    Looking for a decent 55 inch LED TV. Want a good motion rate and basically the best value for money from the deals below. My TV experience is limited and the amount of different models is confusing to say the least.
    My options are a bunch of Hisense ULED TVs:
    55K760UW - £610 / $785
    takealot.com
    55M7030UWG - £640 / $820
    takealot.com
    55U7A - £785 / $1010
    takealot.com
    Other options is to spend up and get a Samsung QLED:
    QA55Q7FBMKXXA - £1040 / $1330
    SAMSUNG 55" SMART QLED TV - QA55Q7FBMKXXA | Get the Best Deals at gettingadeal.co.za
    Or LG OLED, if the price justifies the quality compared to my other options above: (This one is 65 inch , but just because I can get a good deal on the 65, going 55 OLED will be just a little cheaper)
    LG 65 C7 - £1640 / $2100
    LG 164 cm (65") Smart 4K OLED TV - Lowest Prices & Specials Online | Makro
    Any advice is greatly appreciated. Kind regards
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,211
    +4,407
    If you really favour the best motion options you should look at the Sony XE85 or XE90 series, failing that the new XF90 series.
    However you could argue that the LG OLEDs from 2017 offer the best value and if you can get a 65" LG C7 for as little as that I would snap their hands off. Its a lot better value than anything else on your list. OLED motion is brilliant without motion blur.
