Hi. First post. I'll try to be as brief as possible.
Presently: Optical TOS out from TV goes to 1990s Sony amp + speakers. 80W per side true RMS. 320W total PMPO.
Why change? Want 5.1.
I do not want audiophile stuff. I'll happily run 70W speakers on bell wire. I just want a solid, full proof set up without going so cheap I regret it and have to buy the more expensive option anyway.
Currently I'm look at the Yamaha HTR2071. Seems a basic enough non-network 5.1 reciever that will support 4K passthrough and active sub.
Yamaha do that as a kit with speakers and a passive sub for £499.
RicherSounds (UK) do the same Rx with Wharedale DX2s for £599.
I might give Sony options a look too. There stuff is usually solid.
Use Cases:
PC Media Centre HDMI -> RX -> TV : Stereo or Dolby 5.1 (depending on app and codecs) (or maybe just eARC this too, it depends on if the dedicated PC input is also the eARC output or not)
Smart Tv -> eARC -> Rx: Stereo or whatever Dolby/DTS codecs it's supports.
So.
Rx
Speakers
30m Cable
2x Rear speaker wall mounts
2x Front speaker stands.
1x staple gun
1x carpet prodding, pushing tool to push the carpet back into it's grip runners? (Screwdriver?)
HDMI cables (Surely "High speed HDMI" cables are a scam?)
RCA phono for Sub (if active).
Anything else I need?
Use Cases:
So.
Rx
Speakers
30m Cable
1x staple gun
