Sandman
i know this is the wrong forum for this and if the mods want to move it that’s ok with me. I only posted in here as it gets more traffic and I suspect a lot of regulars in here will be able to help.
My elderly and disabled dad is always having problems with his PC and I seem to be his 24hr support helpline (he is only a few miles from me).
Anyway his PC is prone to completely freezing at times and sometimes for hours at a time. Today he phoned to say the sound has stopped working. I went round and couldn’t fix either issue. I suspect his HDD might be faulty and I will test the sound with a different set of speakers when I go round tomorrow. The PC is about 6 years old and runs W10.
Is there any diagnostics software (free) you can recommend to pinpoint the problem? Last time he had the freezing issue I wiped everything and started again with a clean install so I suspect a hardware problem rather than a software.
I also assume if he needs a new HDD he will also need to purchase a new copy of W10 as the pc came shipped with windows installed which was then upgraded to W10.
