Help me fine tune my mission M7ds speakers
Discussion in 'Home Cinema Speakers' started by Bristol Pete, Jan 12, 2003.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Currentlyusing the Mission M72 set which as the review states is very dynamic, has superb punch and wonderful sound full stop. However, I am a little concerned that the rears can sound muffled.
    Is this the sound of bipole diffusion or can I tweak my amp's graphic equaliser to set them a little better.
    So, can any one recommend and setting for the bass, treble and hz to mhz options on my Sony SRTDB870. Also, as advised by Mission, the rears are set to large as they tell me they can handle it as long as I do not watch at reference level all the time. What do you think..?
    Finally, would anyone say that this set up is better than a sub sat system, as with the exception of the few, most sub sat systems seem to lack dynamics etc. I am just wondering if I should have gone down the 'expensive' sub sat route after all..but then I do that with everything I buy.
    Thanks for any advice,
    Captain Benefiit.
