help me find this bracket please
Discussion in 'Home Cinema Buying & Building' started by peahead, Mar 21, 2005.
  1. peahead
    peahead
    Dec 14, 2002
    2,843
    St.helens
    +277
    Does anybody now were i can get a vogel efw 2000 wall bracket for my 27"sagem lcd tv which was recommended by sagem i have googled it and been to vogels website but could not find that model of bracket is there any other brackets that will fit.
    thanks :lease:
  2. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    Saw Vogel wall brackets in John Lewis and Bentals in Kingston today if that helps.
  3. alscds
    alscds
    they more than lickley meant use the 2000 series bracket. you may have to cut down the upright bars slightly and this does not void your warrenty also you may need an extra fitment plate johnlewis stock the vogels range as do many other retailers so you wont have a problem getting one. bbg are the only importers of vogels in the uk. so if your in any doubt contact them ok
    tel : +44(0)20 8901 2662
    fax : +44(0)20 8863 7119
    www.bbg.eu.com
