Help me find dvd-a & SACD's I'm going mad!
Discussion in 'Music & Music Streaming Services' started by JUS, Sep 9, 2003.
  1. JUS
    JUS
    Jan 21, 2003
    3,421
    Plute
    +317
    Ok. I've spent the last hour searching through the recommended websites and I couldn't find a site that does the following simple things :mad: ...
    1. Sells SACD & DVD-A
    2. Makes them easy to find.
    3. Displays both the Artist and title of the album.
    4. Tells me whether the SACD's are multi channel.
    Can anyone recommmend a site that does all of this :confused: .......please :)
  2. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +10
    I too share your pain.
    Anyone out there to help us please :)
  3. Jsinger
    Jsinger
    Aug 26, 2003
    40
    About the most comprehensive and organised listings of SACD and DVD-A that I've found is at MVC (check the links on the left of the page).
    Still nothing I want to buy there though :rolleyes:
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    Aldershot, Hampshire
    +286
  5. JUS
    JUS
    Jan 21, 2003
    3,421
    Plute
    +317
    Thanks for the links Hawkie :)
    I looked at dvdboxoffice before...they don't seem to do item 4 on my list :( well, on the discs I looked at anyway.
    play looks more promising. I looked on the playusa site and couldn't find dedicated sections. I thought the usa site would have more titles.
  6. Kevo
    Kevo
    Aug 23, 2001
    5,395
    Manchester
    +147
  7. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    try - http://www.dvd4music.com/
    not the cheapest, but have a good selection...
    a quick query tho, with the system I've got (see my signature), I've connected my av amp to my dvd player using 3 sets of phono leads and I've got 2 dvd-a discs (pogues and rem) and an SACD (mike oldfield), but only the REM plays multichannel...any ideas..?
    ta.
  8. JUS
    JUS
    Jan 21, 2003
    3,421
    Plute
    +317
    Tried futureent before and I just couldn't find them. Hooray for urls :)
    Babble...I found the set-up of my 565 quite tricky. Especially as I am connecting to TV and amp.
    For SACD you need to set your player to play the multi channel tracks. My 565 was defaulted to play the CD or 2 channel SACD tracks.
    DVD-A. Some discs seem to default to 2 channel. I think you can press audio on your remote to cycle through the possible options.
  9. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    thanks JUS, will check this out tonight...
  10. OnTheFly
    OnTheFly
    Jul 2, 2002
    2,943
    83
    Everywhere
    +119
    Try www.dvdpacific.com
    A good little company and you will not beat their prices. It's best if you order two which helps with the postage and they take about a week to arrive.:hiya:
  11. Rich
    Rich
    Sep 15, 2002
    2,257
    warrington
    +137
    amazon do a good range of both,just enter either sacd or dvda into the search box
  12. Stevie S
    Stevie S
    I'd recommend www.play.com
    They seem to have the best prices around, generally good, fast service. Some of their items (esp SACD) do seem to get a little hidden. I had to do some searching to turn up the Alison Krauss live SACD. Their hybrids tend to turn up in the standard CD section.
    Their Dylan SACDs are now in stock and shipping
    Stevie
  13. JUS
    JUS
    Jan 21, 2003
    3,421
    Plute
    +317
    Thanks very much for the replies. Here are my comments...
    Play.com fails on item 2 on my list. You select sacd and you only get a list of 5 or so discs. You've then got to top selling to see more...but what if the music I like isn't top selling where do I find it?
    Amazon fails on item 4. Also repeats titles over and over again as you page down :(
    dvdpacific are good. Once you realise there is a little hyperlink thing in point6 font on the top right of the music page. They eventually fail on item 4 as well.
    dvd4music seem to be the best. Although it would be nice to pick the genre. paging through all the classical music is a bit boring.
    dvdboxoffice seem to have improved their site. You can actually filter by format and genre. So for instance you can select dvd-a, sacd and pop. ALthough they fail on item 4.
    I didn't think I was asking for much. Maybe I'm getting fussy in my old age. I have to combine the info from two sites to decide whether to buy a disc :rolleyes:
    Jus
  14. Stevie S
    Stevie S
    In its defence, you *can* browse SACDs by genre at play.com
    Also bear in mind that many of their hybrids will turn up if you do a search on the standard CD page. If you try typing "hybrid" in the CD title search engine, it yields 65 hits.
    Stevie
  15. Rich
    Rich
    Sep 15, 2002
    2,257
    warrington
    +137
    sony.com has a lot of information about sacd's doesn't have all the titles available,but it has a hybrid section and a multichannel section
