Help me Figure out this problem with my True Wireless Earbuds and my Phone
Gozbot
I have tried to Google this problem and I cannot find any result that resembles this problem. No reviews of these devices mention this issue anywhere, from Amazon to Aliexpress.
You guys are my last hope. Please help me.
I use an Infinix Zero 6 Phone
Here is a Link to the GSM Arena page for the specs.
Here is my journey with three different earbuds.
I ordered my Edifier TWS 1 Pro off the eCommerce Platform Jumia.
The first set arrived and I tested everything.
Everything worked except one thing.
I couldn't hear anything during calls.
When I first made the call, it sounded for 1 second and then the sound went off.
I could hear music playing on the phone and on my laptop but I could not hear anything immediately I hit the dial button to make a call.
If I switched to speaker or headset, I could hear the sound of the ringing.
I called my second device a Zinox Zpad X7 from the Infinix and I could not hear my own voice as I spoke into the microphone of the Zpad.
I connected the earbuds to the Zpad and I called the infinix and the same problem persisted.
I tried everything.
I enabled developer options and I tried the switch the Bluetooth codec to AptX but it just wouldn't change. It kept going back to SBC.
I reset all app preferences but the problem didn't go away.
I figured it was a defective unit and returned it.
I ordered for another Edifier TWS 1 pro.
The second one arrived and I tested the calls immediately. At first it looked like it was not going to work, then it did.
The next day, I was on a call when the sound suddenly went off when another call came in while I was on the first call.
The problem had returned.
I connected to the Zpad and the problem was still there.
I brought a third phone, an Infinix Note 4 and I connected the earbuds, the sound returned. I connected back to my Infinix Zero 6 and the sound was there.
Two days later, the problem returned.
I never bothered to connect it to the third phone. I connected to the Zpad and the problem remained so I just ordered a return.
I decided to go for another model, reasoning that perhaps my phone was not compatible with the TWS 1 pro.
I ordered the Edifier X5.
It arrived and the same problem started. At first, I heard the ringing sound for a second and then it cut off. I didn't hear anything again. The problem was back.
I connected to the Zpad and the problem persisted.
I connected to the Note 4 and the problem persisted.
I took the fourth device. A Xiaomi Redmi 9C which runs android 10.
1. I connect the Earbuds and make a call and I can't hear anything. Then I press the volume down key and I hear the ringing.
2. I switch to my Infinix Zero 6 and I make a call and I can hear the ringing. I press the volume down key and the sound stops.
3. I switch back to the Redmi 9c and repeat step 1, the voice comes back.
4. I connect to the Zinox Zpad 7 and it works. I press the volume down button and the volume up button and it still works.
5. I repeat step 2, same result.
PLEASE WHO CAN HELP ME UNDERSTAND WHAT THE PROBLEM IS AND CAN OFFER ME A PATH TO THE SOLUTION.
Thanks!
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
