NPM108 said:
Hi Kazman, Thanks for the info. I read through your posting on the Marantz amps and am pretty interested in the SR7500 but its available locally in Malta. I've never owned one before and my only hesitation is that they occasionally don't fair so well in reviews. I know magazine reviews should be taken with a pinch of salt but I tend to trust Home Cinema Choice as a good reference source. So far I don't believe the 7500 has been reviewed yet but the comments I read on this site are certainly promising.
Home cinema choice have reviewed the previous generation (upon which the SR7500 is based), and awarded it a solid 4 stars, and commented on how well it draws you into a movie, especially with its dialogue presentation. The SR7500 is even better
it also has the slam that was missing from the SR7400, auto setup and THX certification.
The Pioneer 2014 I would source from Germany as the local Pioneer agent is charging crazy prices.....
I just want to make sure I get it right. The 630 I have at the moment always gave me the impression of being soft and I find dialogue from the centre speaker to be bad, just not clear and crisp. First I had a Paradigm CC-350 centre which I always liked but when I got the Yam it seemed to drop out. I then went through changing to the KEFs but kept the Paradigm centre...eventually reaching the conclusion that the tonality of the system wasn't matched so I got the KEF Q9c, which if anything didn't sound as good??!
The Q9c is a very good centre, I'm wondering if it is more difficult to drive than the paradigm, hence the difference? Someone else probably has more knowledge on this than me though. The dialogue presentation on the Marantz is truly sublime though.
I've invested in decent speaker cable, there's some Monster stuff and some THX approved cable as well in my system and just spent a fortune on interconnects as well, QED P75, QED QNect for Optical etc.
My current player of choice is the HD935 from Samsung, but I don't think thats the sound culprit though perhaps slightly??? Was running a Tosh SD220E before and it seemed to sound better.
Any of the amps you have mentioned will have better DACs than either the Samsung or the Toshie, so use the digital connection
and the DVD player will be used as purely a transport.
You mention the Pioneer has having the most in your face sound..... does it still have good steering and is it still clear or would it be similar to comparing a sub running in Slam or Depth mode (in the case of my REL!) to understand this better?
The Pioneer is very direct, and is not embarresed to throw sounds around, to quote what hi fi this month on their review of the Pioneer 814 "It's like having a bull in a china shop", meaning that it isn't exactly delicate. Some people like it, some people find it tiresome, I'm in the latter group
. It will give you a massive soundstage, and is probably the movie mans choice. Dialogue 'may' suffer though, you will hear it fine, but it won't be as well defined as the Marantz, whereas explosions will be better defined (but only slightly) on the Pioneer.
One last question as both of these amps have auto setup function..... my seating position is around 6m away from the screen/receiver. Do I need to put the mic in the seating position area and if so is the cable long enough.
It should be fine, I know the Marantz came with a very long cable, and my seating position is about 4m's away, the cable still had a LOT of slack.
Thanks everyone for helping with this.....
No problem
, we are here to help
One thing I will throw out though is this, how important music is in movies, if you listen carefully on most amps, you can hear the background music, and it is there for a reason, to enhance the movie, not many amps I've heard so far are able to bring the soundtrack of a film to life more than the Marantz, and I for one, would choose that over a bit of extra slam. The Arcams also do this very well, and the Rotels.
Sometimes, the emotion of a movie is overshadowed by the explosions, the Marantz doesn't let this happen.
One film that really brings this to light is Love Actually, ok, not the best film out there, but it IS a movie which highlights how important music is in a film. Just my 2p
And remember, this is all subjective
