P
pgres
I want to get a DVD recorder and a friend told me I should get a DMR E50. I have been looking around and it seems that the E50 is well worth getting but I would like to know what the difference is between the E50 and the E60. Is the E60 a better machine and if it is then how much more expensive would it be? Also have read that the 50 and 60 are to be replaced by the 55 and 65. Does anyone know how much better these new machines will be and how much more expensive they are likely to be. Should I go for the E50?
