Help me cut my short list down further !
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Deejah, Jun 8, 2005.
  1. Deejah
    Deejah
    May 19, 2005
    114
    19
    Surrey
    Hey all
    been retying to make a shortlist of a decent hifi setup then pop into seven oaks to demo. Tho my shortlist is actualy quite large :D and i wanna chop it down a bit further so i dont spend hours and hours demo'ing it all with all the possibilities :smashin:
    So far for the amp i have narrowed it down to...
    NAD C352CT, Arcam A65 plus and Rotel RA02
    CD Players...
    NAD C542, Arcan CD73 & Rotel cd02
    Speakers....
    Yet to be decided upon, but roughly on a budget of 400/500 ish
    The setup would mianly be used for rock/metal. With the odd spalsh of other things. Any info would be great fellas :thumbsup:
  2. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    The NAD is loud and quite "gutsy" not necessarily the most accurate probably the Arcam for accuracy and the Rotel is in the middle.
    So depending on what you want each of them could be ideal :)
    For Rock/Metal I would actually consider the Nad it's a fun amp and just rocks. don't know why but to me it's that sort of amp.
    If you can listen to all 3 and decide for yourself.
    Steph
  3. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Oh you've made no mention of speakers, do you have these already, or know what you want to go for?
  4. Deejah
    Deejah
    May 19, 2005
    114
    19
    Surrey
    Not really sure what to go for, its a bedroom hifi setup so my room is only about 3.5m by 2.5m
  5. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    So small speakers :)
    Don't know how small, I suppose B&W 600s3 or Kef Q1c's would be quite acceptable, there are also some quite nice baby mission speakers around at the moment.
    Steph
  6. Deejah
    Deejah
    May 19, 2005
    114
    19
    Surrey
    Thanks for the help, i'll demo some of the setups in sevenoaks and swap it around with a few diff book shelf type speakers.
    Not really sure where to demo the nad with B&W speakers tho, i know my local richer sounds does the nad stuff as sevenoaks dont stock them. But not totaly sure if Richer sounds stock b&w speakers, which would be a shame.
  7. CJROSS
    CJROSS
    Nov 16, 2000
    5,070
    +343
    Rotel Combo + Castle Richmond 3is. Then add an active sub when you move to a larger room.
  8. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    My view is that the speakers have the biggest ‘sonic signature’ to the sound of the system.
    I would be more inclined to select the speakers first, and then the electronics would automatically be reduced.
    I do like the idea of standmount speakers supplemented with a sub. Do you have room to mount them on stands, or will they be on a bookshelf (or wall mounted)?
  9. Deejah
    Deejah
    May 19, 2005
    114
    19
    Surrey
    thanks for the post harry, went into seven oaks the other day, and demo the equipment, and i came out with the rotel combo with the b&w 602 s3, large bookshelf speakers but sounded very nice, i demo'd the quad 11 L'sbut prefered the sound of the b&w's.......tis a shame they had everything in stock bar the speakers :D
  10. CJROSS
    CJROSS
    Nov 16, 2000
    5,070
    +343
    Shame you did not hear Castles with them Deejah, :D Enjoy your new system looks a good-un.
