Help me create my own Calibration Discs
Discussion in 'Home Cinema Buying & Building' started by Dom H, Jul 7, 2002.
  1. Dom H
    Dom H
    Looking at the other calibration discs theyre v expensive for what they are so I thought I'd give making one myself a bash.
    It will have to be in VCD format which I can burn on the comp with nero.
    Video Calibration
    Seeing as I use RBG, colour is not adjustable so I need the correct image to calibrate brightness and contrast only (and perhaps sharpness). What image is usually used to calibrate brightness etc. for pal sets?
    Audio Calibration
    I beleive white noise is usually used for this, problem is how can I create 5 separate audio tracks, each one playing white noise from each speaker? I presume it will have to be dolby digital or possibley mpeg audio, what can i use to create these?
    Anything else I need on the disc?
    Many Thanks
    Dom.
    *edit* hmm looks like I'm stuck with 2 channel audio on the vcd, spose I can flip the interconnects round on the amp using a 2ch mix.
  2. Dom H
    Dom H
    bump.
    What type of noise is used on the proper calibration discs, white or pink noise?
  3. juboy
    juboy
    For a tenner you can get Video Essentials at www.ezydvd.com.au
    I'm thinking you may save yourself a lot of time and effort on something that may not be of too much use...
  4. jonny m
    jonny m
    Mar 22, 2002
    405
    I can't find the video essentials at ezydvd are you sure its there? When I search for it it comes back nothing found.
    I could really use this disc so any help appreciated.
    j
  5. juboy
    juboy
    Jonny: this is the exact link
    http://www.ezydvd.com.au/item.zml/552
    The list it as Ultimate Dvd Platinum rather than Video Essentials, which is probably why your search failed.
    I'd advise anyone who wants it to get cracking with their orders as I would guess their stocks will be running dry soon at that price.
    For reference, I ordered it from them and the service was great. From Aus to the UK in around 4 days! Dirt cheap too.
  6. jonny m
    jonny m
    Mar 22, 2002
    405
    juboy
    Thanks, the price does seem really cheap I wonder if any of their other stuff is that cheap.
    j
  7. Squirrel God
    Squirrel God
    It is, but you have to be selective and remember to add on the postage ;)
