HELP ME!!!!!!!!! choose
dickst3
Ok, so how do you know its one of those?
What requirements do you have? What size (they are three different ones!)? What budget?
H
HELLraZorsMiThY
LCD, HD READY, looks good on my Xbox360 games, 27'' or less, £550 MAX
dickst3
Mmmm, well, that does not rule out others such as a Panasonic.
Just to confuse you a bit more!
Woodywizz
HELLraZorsMiThY said:
O well i am leaving these forums, there S**T:hiya:
A little bit of a knee-jerk reaction don't you think?
Anyway, best of luck in your GCSEs next year and I'm sure they'll welcome you back with open arms here.
dickst3
call me niave but i thought he was joking :(
you try and help some people.....:rolleyes:
well, if it has to be one of those three. forget the first its not out yet. then do a search for reviews on the other two and get the one most raved about - simple
Nielo TM
Avoid all three of them. The R7 is good but it uses PVA not S-PVA, the only below is very old and no match for the rivals. The third one is an old model.
I strongly recommend the
