Help me choose...
Discussion in 'Home Cinema Speakers' started by monkeymac, Jan 13, 2002.
  1. monkeymac
    monkeymac
    Hello there.
    I need help choosing between these HT speaker systems:
    DENON SC-50
    YAMAHA NS-P320
    As you can see I'm on a pretty limited budget for a 5.1 system.
    Also could you tell me if the Sony HTK-475 complete home theatre system is any good. This could be another option in my search for a budget HTS.
    Cheers.
  2. monkeymac
    monkeymac
    Hello? Anyone?
  3. monkeymac
    monkeymac
    Well thanks a bloody bunch.
    I can't believe more than 30 people viewed my predicament and decided not to help me.
    I fart in your general direction. Your mother's were hamsters and your father's stunk of elderberries.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Come on monkeymac... It's a very vague request, and it hasn't even been up for 24 hours yet. Give people a chance.
    I've viewed your post before, but what response are you looking for? Are you wanting someone to tell you exactly what to buy? No one can give you that answer but yourself. Do some research of your own into the kit and see which one you prefer yourself. If you have any specific questions about the systems, you'll get a much better response than just asking 'which one should I buy?'.
    Have a bit of patience.
  5. RC
    RC
    No one is obliged to help you and with the kind of attitude you've demonstrated, the likelihood goes down. Perhaps the 30 people who looked at this page, like me, have no particular knowledge or insight into the equipment you mentioned. :eek:
  6. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    94 have now looked at this thread including me several times as the heading is unclear and I can never remember what the question is about.
    Unfortunately whilst I would like to be helpful I have never heard of any of the three options so cannot give an opinion.
  7. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Have you looked at the Yamaha HTIB40 complete with 5.1/DTS receiver and 5 satelites and subwoofer (NSP220 I think). I was considering the Sony HTK475 as well but I bought the Yamaha on recomendation from a hifi shop and What HiFi (5 Stars).
    I think it sounds pretty good in my living room (17'X13') and may be just the thing for someone on a smaller budget. £379 at hispek.com who delivered one to me next working day.
  8. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    209
    Scotland
    +4
    I've got the NSP-300 and whilst they were cheap they're not too bad as a starter system.
    If I had my time again though I would go with some older missions from RS or something like that. Not too much more money and I would bet a whole lot more performanace!! See the mission thread...
    That do you?
  9. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,690
    Inbetween Upgrades !
    +8,142
    monkeymac,
    I think you need to read these forums a bit closer.
    You specifically asked on 2/3 all in one systems. How many people do you think will actually own these systems?
    You will get all those views by the sheer nature of your question. As the question was so open that entices people to have a look. They will then not reply with 'i dunno mate' as it is pointless.
    These forums are very good and people will give you all the help that they can. As it has been suggested do some research yourself first. This will then help with further questions, and do please be patient.
    And most of all DONT BE SO BLOODY ABRUPT !!!
    Kevin
