Help me choose...
Discussion in 'AV Receivers & Amplifiers' started by monkeymac, Jan 13, 2002.
  1. monkeymac
    monkeymac
    Hello there.
    I need help choosing between the KENWOOD KRFV5050 and the YAMAHA RXV396RDS. Which is the better receiver and why?
    I'd also like to ask if the KENWOOD allows you to connect an active subwoofer. I don't think it will but I'd like some confirmation.
    Cheers.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    All amps with a Dolby Digital decoder within should have a subwoofer output as it is the .1 part of 5.1.
    I have not heard the Kenwood but from reading reviews and other members opinions it would seem that both offer good value for money.
