Help me choose
Discussion in 'Projectors, Screens & Video Processors' started by triton, Sep 16, 2004.
  1. triton
    triton
    Sep 16, 2004
    7
    Glasgow
    First Post, so go easy please ;)
    I've been reading the posts searching for info thanks to all who contribute.
    I'd like to get a Projector and screen.
    I'd thought that I'd go for the H30 themescene model. but it was talked down when I visited the local Store. They Suggested instead that I go for an infocus SP4805.
    Since I couldn't see iether of these in use. can anyone who has seen both of them comment on the pro's or cons of each, and is there another that I should be looking at. I want to kep the bill under 2K GBP for screen and projector.
    regards
    triton.
  2. Skyav
    Skyav
    Jul 20, 2004
    91
    Hilo :hiya: ,
    It's been my experience, and that of a couple of friends, that a store will often try and sell you whatever they need to shift. If a particular model isn't in stock and there's a risk that you'll go somewhere else instead, some may try and push an alternative just so they can get a sale.
    I'm not suggesting that's definitely the case here, nor am I suggesting that one make is superior to another - it's just something I've noticed on occasion.
    I think you're doing the right thing...check out as many forums and reviews as you can and try and get the projectors demoed wherever possible.
    I recently picked up an H30 which I am very pleased with. I think the image quality is excellent - very smooth and filmic. I never bothered with a screen - I'm just projecting onto my wall! It's not even pure white , and has a couple of bluetak stains, yet that doesn't seem to impact the image quality at all. I'll probably give it a proper coat of matt white at some point soon though.
    I guess my point there is: Think twice about spending a ton of cash on a screen when that money can go into a better projector....unless you're really going the whole hog, or haven't got a spare white wall to hand...
    I can highly recommend the H30 due to it's deep, rich colours, quietness and 4xspeed colourwheel, and Optoma/Themescene have a 3-year 'replace and return' policy which is pretty groovy. But then check out what's out there - there are many excellent projectors on the market.
    :thumbsup:
    Skyav
