help me choose please??
B
boogi11
Hi all, Im new to this forum lark but lets give it a go. I had a sony DAVS400 home cinema, it fried itself last sat!!, hence I need a new one. My budget is about 450 pounds. I have been looking at a pioneer NSDV77??? but im not sure, i would prefer scart as opposed to the other sort of connection, and i bought some nice speaker stands, except they only have a small feed hole for the cable, so it would be nice if the speaker cable was detatcable from the speakers so I can feed it through the stand (not overly important though),
Thats it through some ideas at me.
Boogi
hornydragon
Have a search around few people will reconmend an all in one, but the the Yamaha HTiB45 has had good reveiws as it is a separate receiver with speakers. add a DVD and you are away the Yammy and a pioneer 454 or similar should be in range Just
Look at:
www.hifibitz.co.uk
www.superfi.co.uk
www.richersounds.co.uk
www.avland.co.uk
www.qed-uk.com
EG at QED
YAMAHA HTIB45 CINEMA PACK SILVER
High Street £429.93 QED Price £334.35
PIONEER DV-454-S DVD SILVER
High Street £179.99 QED Price £129.57
Total £463.92
Shop around and you could be in for £450 or less leaving you sum for decent cable.
Please do your own research and try to hear the kit see it before buying it's worth in the long run
:confused: :confused: :confused:
If you stilll have the speakers look at this could be what you need
