Help me choose, NAD c320bee/c370
Discussion in 'AV Receivers & Amplifiers' started by Sh4rk, Jul 6, 2004.
  1. Sh4rk
    Sh4rk
    Apr 13, 2004
    92
    Winchester
    Which should I get and why? This is disregarding price.
  2. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    370, be a slut and go for the extra power :)
    Listen with your speakers... The 320EBB is slightly newer might be better if you don't need the extra power, but the power of the 370 is quite nice and fun if you want to play a little bit louder and keep control. Also in fact I find the more powerful amps actually allow you to play things a bit quieter and you don't loose the voices as you would with a smaller amp.
    OK when the nads are concerned i'm a power slut :)
    Steff
    The easy and most sensible answer is listen to both and whichever one you enjoy the most get :)
  3. Sh4rk
    Sh4rk
    Apr 13, 2004
    92
    Winchester
    I don't think I will be able to listen to them before I buy but how do they both compare to the 350 as i have listened to that quite a lot? Anyone got any more opinions on my choice?
