Help me choose.... Garmin 310D v Tomtom 510....
MOz10R
Gonna buy one of these for the missus for Xmas.... problem is, which one????
Need a good battery life, postcode search and reliable clear and easy to use Bluetooth connection for the handsfree option.
Can owners say whats good and whats not about them?????
MOz
per-Sony-fied
The Garmin in general gives a longer battery life upto 8hrs I believe... depending on type of usage.
The TomTom gives a quoted 4hrs but I've manged 5+hrs on mine. The hands free bluetooth function works well but it really needs the external microphone for a clear conversation.
Both do 8 character postcode search.
The TomTom is very easy to navigate through and has a very good touch screen. Main gripe about it is it doesn't seem to take you on obvious routes although it does have an alternative route planner. Once at your destination and ready for home you need to check the route (rather than just clicking home) to see if it differs from the route it took there as it can take you an entirely different route! However it does have a favourites folder where you can save journeys.
I'm afraid I don't know to much about the Garmin although it does use different mapping (Navteq) although TomTom is now from what I hear using both mapping companies which include TeleAtlas.
MOz10R
Thanks mate....... helpful.
I chose the Garmin due to battery life, size and the deal was great.
MOz
