help me choose from the following
Discussion in 'General TV Discussions Forum' started by davcohen, Feb 13, 2005.
  1. davcohen
    davcohen
    Oct 12, 2004
    7
    ok i have decided i want to go for a phillips Tv after seeing the quality for myself, would love the 32PW9509 but its outta my price range
    i have narrowed it down to the following:
    Philips 32PW9309C
    32PW9308
    36PW8719C
    i know the last is 36"s but is there any other difference's as in technically, not to worried about looks between them?
    i am interested to hear about other brands aswel if you think they can top any of these sets for around the same money, i saw that toshiba 36" that JL have but they wouldnt price match as they called and someone told the salesman £1095 either way the quality again was nowhere near as good as the phillips it was next to
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    A lot depends what you view the most.I personally found the pixel plus processing of the philips overbearing with sport and action films.If you mainly watch dvds check out the panasonic pd range they are awesome.For mostly sky or freeview i would suggest the excellent toshiba 32zp48.They have a slightly softer definition which works better with sky etc.Superb sound too.You didnt mention your budget but both these tvs are around £800.
  3. davcohen
    davcohen
    Oct 12, 2004
    7
    i could top out at £800, i am looking to buy very soon as in the next day or two as i got sky coming friday but nothing to watch it on.
    i dont want a rear projection because of the viewing angle problems and the problems with the tube's, is this a CRT based set KP-44PX3U?
    i basically want the best quality tv with the biggest screen size for around my budget of £800
