First, thank you all (in particular Dodgexander) for all the advice given here on AVForums. I’ve used his recommendation template here - please help me select a TV or a few options to pick from!
I’m conversant in some tech but not really AV stuff, so appreciate help given as if I were a beginner. My viewing setup is pretty simple: a couch directly opposite the TV. Distance between TV and viewers will be about 260 cm (~100 inches).
FYI, I’m in Apple’s ecosystem for basically all my other devices.
Which external devices do you plan to connect to the TV?
- Audio streamed to 2x HomePod Minis, one on each side of the couch. (Ideally the TV would be able to stream the audio to them, in stereo, with Airplay.)
- Open minded on an Apple TV (or ATV4k) if it makes the setup better/easier
- May want to connect computer (MacBook Pro with AMD Radeon Pro 5500M graphics card)
- Hard drive: have a bunch of movie and TV show files I ripped from physical media - some DVD, some in 1080p, one or two in 4k. (I’ve now ditched almost all physical media and will try to get any new purchases in digital form.) Will want to be able to play the video files from hard drive as simply as possible - on my computer I use VLC player.
What content will you watch on the TV?
- Streaming: Netflix (Standard plan, not premium), Amazon Prime, Disney+
- YouTube
- Movies (from files, not physical media)
- Catchup: BBC iPlayer and maybe Channel 4
- Will only rarely use for broadcast TV or sport
- No gaming
Viewing proportions (probably):
40% SD (would like decent upscaling so it looks good)
40% HD
20% UHD
Viewing proportions by content:
35% HD Blu-Rays (digital files)
30% Streaming TV shows & Movies
15% UHD Blu-Rays (digital files)
10% DVD quality files
10% Broadcast TV shows
Will you use internal or external apps or tuners for the following? If external, via which device? Broadcast / Streaming / Catchup
- Plan was to use built-in apps but could always stream them via Airplay or use an Apple TV, whatever is least faff and will work easily with the HomePod minis
Situational questions:
- Definitely a ‘set it and forget it’ kinda guy, but will do some basic tweaking if it’s easy
- 260cm viewing distance
- All three seating positions fall within about 30 degrees of the centre of the TV (so I assume a tv with a VA panel)?
- Lighting:
- - Bright to medium-bright in the day
- - A bit darker in the evening but not blackout dark unless a movie night and intentionally shutting every light off
- Use = not at risk of OLED burn-in
- No legacy connections needed
Rearrange the following, in descending importance:
Cost (~£500-600 max, ideally less of course)
SDR Picture quality
HDR Picture quality
Shadow detail
Blacks
Value
Smart TV ease of use
Picture accuracy out of the box (without pro calibration)
Smart TV app selection
Sound (will be using speakers)
Viewing angles (don’t need wide ones)
Possible pet hates related to TVs:
- Honestly, a lot of these are over my head as a non-AV guy. I want relative ease of use, reliability, speed, and good upscaling as I’ll probably watch a lot of non-4k stuff on it. Decent performance in light conditions also useful
Other stuff
Airplay is probably important - I know an ATV box provides it, but aren’t there some limitations running everything through ATV all the time? And will the TV upscale content if delivered to it through an ATV? (This is as much a help/advice post as a TV selection post!)
Size between 49” and 65”; I was thinking around 55” but open to whatever might make my content look best.
Thanks so much for any help! Looking to select a TV this month and I guess buy a 2020 model, unless earlier years would fit my reqs fine
- YouTube
- No gaming
40% HD
20% UHD
- Lighting:
SDR Picture quality
HDR Picture quality
Shadow detail
Blacks
Value
Other stuff
