help me choose a tv plzzzzz
peve3
hi there guys !!!
i need help buying a new 36 inch tv i have been serching 4 ages and its a cross between
The 36 philips inch pixel plus !
and the new toshiba 36 inch with component in !
i will be using the tv mainly 4 my vast dvd colection and my computer consoles xbox,gamcube,ps2 !!!
i would allso like to no whether the component in pal compatable!!
plz help THX !!
philipb
"Which TV to buy" questions usually just get people praising the one they bought, or warning you off a set they had a bad experience with. Either way of little use. Search the forum for posts on these sets and draw your own conclusions.
I have the pixel plus set and have been knocked out by it. There are those who swear the Tosh is much better with DVDs because of the component in. I researched all the sets before buying, and watched them all, broadcast and DVD. I chose the 9607 and have never regretted it.
I think you mean is the progressive scan done by the set compatible with PAL. Region 2 DVDs are not compatible with PS, not yet licensed. Is the component in better than an RGB scart? Difficult to say. If you have a lot of R1 discs and DVD really is your main priority the go for the Tosh. Actually rob a bank and buy the Panny plasma - no better way of watching DVDs if you can afford it.
Sorry this is a bit vague but I did warn you.
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
