Pulsar
- Joined
- Jan 19, 2003
- Messages
- 3,428
- Reaction score
- 485
- Points
- 832
- Location
- West Midlands - Stourbridge
Hi guys.
After quite a big system change around, I am currently sub-less and looking. Here is the system it is going to be used in:
Denon 3805
Fronts: Quad 11L
Centre: Gallo A'diva
Rears: Gallo Micro's
I may change the A'diva to a Quad L series centre at some point, but not for a little while. The room I am using is about 14 feet by 10 feet, and is now dedicated to HT.
I am not looking to spend a load of cash on a sub, as the rest of the system doesn't truely justify it at this point. So far I have thought of the following:
* 2 Velodyne CHT-R 10's
* 2 BL XLS200's
* BK monolith
* Servo 15
I like the idea of using a pair of subs, as I can try to obtain a more even output from them by moving each of them around the room, although I know that this can make setup quite difficult and lengthy.
So I am asking you guys for any valuable info you can give on the subs listed above, especialy on using the dual subs and how they compare. I am also open to suggestions of other subs.
Rob
Denon 3805
Fronts: Quad 11L
* 2 BL XLS200's
* BK monolith
* Servo 15
Rob
