Help me cable it up
Anrasp
Help ...noobie here
-KV32FQ70 2 RGB Scart, 1 Normal Scart
-Pior DVD A565 1 Scart (RGB), 1 Aux Scart (Composite Video)
-Sat Nokia 9800 1 TV Scart (RGB), 1 Aux Scart (RGB), 1 Digital Audio Socket, RF In/out
-JVC VCR 1 Scart (AV1 In/Out) , 1 Scart (AV2 In), RF In/RF Out
-Pio VSX D712 A/V Receiver
I have two Thor Scarts and 2 Coax cables
I was going to do the following :
DVD - > TV RGB THOR SCART
DVD - > AV Digital Coax
SAT - > TV RGB THOR SCART
SAT - > AV Digital Coax
VCR - > TV SCART
Cable TV Rf In/RF Out
But with this setup I wont be able to use the A/V receiver with the VCR
Any alternatives ? Can I connect my VCR to the Scart on the A565 via a normal scart leag ? Will this allow me to use the AV receiver ?
Ian J
You will need a second scart from the Digibox to the VCR so that it can record from satellite. Don't bother with a particularly expensive one as iy will only be a composite signal. The VCR should have audio outputs which can be taken to a pair of inputs on the amp to replay tapes through the system.
Anrasp
Hi IanJ ...10x for your quick reply...appreciated
The VCR has 4 Phono jacks ( 2 In / 2 Out)
So the final setup should be :
SAT - > VCR Normal SCART
VCR - > TV SCART
VCR - > AV pair phono leads
Anrasp
OK i need some additional help. Here is a pic of a part of the setup. I leave out the DVD to TV and the VCR to TV connection since these are quite simple scart to scart connection.
I have another TV in another room. I would like to supply this TV with CABLE and SAT via RF socket on SAT. It seems that I will need to split the RF cable at some point. Any ideas ?
65-inch LG C1 Review coming soon to AVForums
