Help me buy a new HTPC
Discussion in 'Home Entertainment Computers' started by guyb, Mar 23, 2006.
  1. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Hi All
    I need some advice.
    I want to buy / build a new HTPC that runs Window Media Center. I already have the software so I just need to buy the hardware. I have about £600 max to spend and I want a lot for my money :thumbsup:
    Here are my requirements:
    First and foremost it must be silent running
    Case: must be living room freindly
    Processor: doesn't have to be super fast - just needs to cope with all the media center features and be able to play HD stuff. Needs to run silent
    Graphics: not bothered about playing games just need to be able to output HD to my LG HD LCD (DVI/Component/HDMI)
    Hard Drive: needs to be big, fast and silent.
    Sound: need a SPDIF (digital) output so I can hook it up to my 6.1 system for 5.1 audio
    TV: not bothered about this as I have Sky+ and will be maybe getting Sky HD in the future. I can't recieve a good enough TV signal in my area.
    DVD-RW: must be silent running.
    plus all the other bits needed.
    So can anyone help me :hiya:
    Guy
  2. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
    try this from media pc
    CPU AMD (Venice) Athlon 64 3500+ (ADA3500DAA4BW) OEM Skt 939 £113 approx
    FANZalman CNPS9500-LED Socket 18Db £31
    MOBO Asus A8N-VM CSM GeForce 6150 £59 - but I will include SPDIF and TV OUT in that price
    RAM 2X Corsair 512 ECC DDR400 PC3200 £54 (or 2 x Elixir for £51)
    HDD Seagate ST3250824AS 250GB 7200RPM SATA300 8MB Cache - £59
    DVD r DRIVE HP DVD840i Super Multi DVD Writer Beige DVD+/-RW Lightscribe 16x16x DVD RAM IDE £39
    CASESilverstone SST-LC-17 Silver £61
    add a psu and vat and your there or there abouts this is the spec im going to be going for when i get the cash together, no games required so no gfx card the mobo has the n vidia pure vide on on for hd and takes the new h264 codec
    all prices are approx prices
    http://www.pcstats.com/artvnl.cfm?articleID=1898
    cool looking case
    http://www.mediapc.tv/index.html?lang=en-uk&target=p114.html?lmd=38689.919444
    hope this helps
