HELP -- Making DVD's play audio cdr's
Discussion in 'Blu-ray & DVD Players & Recorders' started by not too sharp, Apr 15, 2002.
  1. not too sharp
    not too sharp
    Hello I have 2 dvd players and neither will play home recorded audio cd's, I have recorded on computer and also via a philips 770 using real digital and optical connections.
    I am using AUDIO cdr's
    But I cannot make an audio (CDR) copy play on my DVD units.
    Any ideas please.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,575
    Somewhere in South Yorkshire
    +6,095
    The laser in many DVD players simply cannot focus properly on the recorded surface of a CDR. There are many people who insist that some certain brand of CDRs will work on some certain type of DVD player, but, in general this is a non-starter. Unless the DVD player is equipped with a dual-focus laser, you are unlikely to find a reliable answer.
    Except - if you use CDRW (rewritable) discs then your DVD player almost certainly WILL be able to read them.
    Unfortunately, CD only players generally DO read CDRs but generally DON'T read CDRWs. So, if you want to make discs that you can, say, play in the car and at home on your DVD player, the only reliable answer is a new DVD player - one that is CDR compatible.
  3. laurel
    laurel
    You didn't say which players you have tried, but check here for compatibility:
    www.vcdhelp.com
    In the DVD Player section.
    Laurel
  4. not too sharp
    not too sharp
    Thank you for the replies.
    I will try CD-RW on the CD recorder (philips cdr 770) The two DVD's that do not see the cdr audio recordings are:
    Sony DVP-CX850 (multi beast) and a Sharp DV 700 single play
    Thank you for all help and assistance.
    KH
  5. laurel
    laurel
    Well there's your answer my friend. Neither player is CDR compatible.
    Good news is they will play CDRW though. The difference in price is minimal for the media.
    Laurel
  6. not too sharp
    not too sharp
    Thank you very much
    KH
