E
ericisbacchus
I bought a Magnavox 32" 32MF231D Flat panel LCD. The picture is great, but it is emitting a soft hum/buzz. It's only noticable at low volumes, and muting the TV stops this hum/buzz alltogether.
So I'm wondering, what is causing it? Should I take the set back and get another? Get used to it? Could the amplified antenna I put behind it be causing the hum?
Thanks so much,
Eric
Thanks so much,
Eric
