Help. M-audio card causing start lag on HCPC
Discussion in 'Desktop & Laptop Computers Forum' started by jitter, Oct 30, 2003.
  1. jitter
    jitter
    Hello folks,
    Wondering if anyone can help with this...
    Spec of HCPC is
    Abit Nvida2 M/board with dual ram access.
    AMD Barton 2500+
    40 gig 7200 HD
    512MB (2 sticks of 256 - 1 in each channel)
    M-Audio Revolution sound card (useing digital out to amp)
    ATI 7500 graphix card
    Pioneer 106s region free dvd rom
    win dvd soft player
    dvd genie
    windows xp pro
    VGA straight to Panasonic LC75 XGA lcd Projector @ 1024x768 85hz (optimum for projector)
    Problem;
    When playing any dvd, soon as its in the drive & starts to spin up & play, the picture starts for a second & then freezes for a few seconds, sound drops on & off too, then plays a bit more. If i hit play it does it again but after a few seconds the film continues to play fine all the way through. Its like it takes it 10 seconds to sort itself out (usually by the time its reached the THX logo)
    I know its the M-audio card causing it because if I switch to the onboard audio it plays fine. I need the M-audio for the digital out to the amp.
    Anybody have any idea how to fix?
    Any thoughts appreciated.
    I've looked at the Revo panel & messed with it but didnt help. Whats the ASIO thingy for? havnt messed with that.
    Cheers,
    Ani
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    Land of the Living, Essex
    +45
    Have you checked that you dont have any viruses?
  3. jitter
    jitter
    Yeah mate, its also a stand alone HCPC (no network/dsl connection at all). Have other pc's for that.
  4. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    +45
    how about reinstalling your dvd software
  5. jitter
    jitter
    That was the last thing to install. Plus it runs fine with M-Audio card switched off. It seems that its when the M-Audio goes to output the spdif things go bananas... then it catches itself up & runs smooth.
    Think I'll just have to give it some serious meddling and maybe adjust some bios settings... something maybe upsetting it that doesn't need to be running. Maybe even the pci slot the M-Audio is sat in, who knows.
    edit:
    Forgot to add that its the platinum edition of win dvd if it makes any odds?
    pps: is it worth upgrading my radeon 7500 card yet?
  6. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    I've read about various difficulties with Windvd - have you tried Powerdvd, see if it makes any difference - I find it smoother operationally than Wdvd.
    Sean G.
  7. Kramer
    Kramer
    I'd suggest trying a different PCI slot - sounds like an IRQ conflict. Move the M-Audio well away from the AGP slot & check device manager for conflicts.
    Best of luck.
    :smoke:
  8. jitter
    jitter
    thanks for the input guys, I'll give those a try...
    cheers
    anakin
  9. jitter
    jitter
    Yup, conflict & IRQ probs ... Kramer you were right. Thanks...
    Ani
