Help! looking for a cable for DVD Component to PJ VGA
BigRD
I'm looking for a cable to connect my PS DVD player to a projector I'm borrowing. I'd like to take advantage of PS but need a component to VGA cable. The VGA connector on the PJ is labled VGA/Component.
Can anyone advise on where I could purchase such a thing and what do I do about V&H sync.
Many thanks :smashin:
Joe Fernand
AVForums Sponsor
BigRD
Have you confirmed the Projector takes YUV (YPbPr) via the HD15 input?
If so then its pretty straightforward supplying a 3RCA to HD15 cable - once you re set the projectors menu to accept YUV on the VGA input the H&V pins are not relevant.
As most multi core video cables are 5 core you may want to order a 5RCA (or BNC) to HD15 cable - which you can then use for YUV or RGBHV; the YUV connections are wired to the same pins as RGB so the two are interchangeable.
For once it looks like we may even be able to fulfil a 'local' order - drop me a note with your required cable length and I can give you a quote.
Best regards
Joe
BigRD
pringtef
Imagine the cable you require is going to be [SBB404],
I'm not sure why I didn't look there before posting but that's what I'm looking for. Cheers.
Joe
I've still to confirm the functions and input capabilities of the PJ, hopefully I can select YUV on VGA. If I can't I'll either use S-Video from the DVD player or use my Laptop.
Where's your shop Joe?
Thanks for the help guys :smashin:
jamiev
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
