Help lip sync probs on pw6!?
Discussion in 'Plasma TVs Forum' started by tim k, Dec 22, 2004.
  1. tim k
    tim k
    Recently purchased my panny 6, coupled it with my yamaha dsp a5 but using my freeview box from scart to js tech vga converter im getting lip sync problems. The image on the pw6 is behind the sound, so the sounds are ahead, whats causing this?? and how can i get it sorted, its quite annoying seeing as images are 42inch wide, and you really can see their lips move.
    Ive done a search and i think i might be able to set a time delay on my amp??
    heres the manual if anyone is feeling brave!??
    http://www2.yamaha.co.jp/manual/pdf/av/english/am/DSP-A5.pdf
    thanks ahead!
  2. tim k
    tim k
    forgot to mention ive got the freeview box audio connected via normal phono, and the amp goes out to a mission m7 5.1 system.
