Help, limited space.
S
SteveCac
Ideally I'd like a Flat Widescreen set but am limited to space, so it's either a 24" Flatty or a JVC AV28CT1 will fit.
Anyone got any opinion's?
I'm limited to a width of 740mm (just over 29").
H
headache
I am in the same boat. I was looking at Panny, Philips or JVC 24" but in terms of £/cm they are relatively expensive. I have also been looking at JVC AV28CT1EKS. If you do a search on this model number there are some items of useful info. I am still studying prices and have not purchased anything yet.
Note the JVC does have 3 SCARTs but only one is RGB.
H
headache
Does anyone know why the AV28CT1 has dissapeared from all the shops? John Lewis branches say it is discontinued, but it is in the current JVC catalogue.
H
headache
Ah if life was so easy. I tried that, no reply. Even unbeatable have no stock of this semi diminutive 28in set. I will have to try at the Coop!
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
