HELP...Lamp for Sony vw10ht
Discussion in 'Projectors, Screens & Video Processors' started by Jinxybbc, May 10, 2002.
  1. Jinxybbc
    Jinxybbc
    Oct 31, 2000
    72
    norwich
    My Sony vpl-vw10ht projector is 15months old with a lamp that has just decided to flicker and pack-up ! just when all the kids were round for the Harry Potter showing & only 409hrs on the clock....
    1, Is this lamp the same as the Sony vpl-vw11ht ?
    2, Has anyone had this problem and contacted Sony for a free replacement( 4 ever hopeful)?
    3, Any ideas on the best/cheapest place to buy one ?
    4,All help would be appreciated..thks.
  2. ATUL
    ATUL
    May 23, 2001
    41
    london
    you have mail.
    Atul.
  3. Metric
    Metric
    My 10ht died at about 6mths old with 49hrs on the bulb. Sony lost the unit, accused me of removing the lamp and not sending it with the projector, messed me about no knowing what the problem was and when they finally looked at it found it to be a simple dead bulb. I guess, they didnt have to replace it, although merchantable quality springs to mind. Took them a further 2mths to locate a bulb.
    3mths later, 3mths lost warranty, and 3mths of snotty emails from them to me, i finally got my projector back.
    So will sony replace your lamp? doubt it.
