HELP!!! Kef speakers stopped working!
Discussion in 'Home Cinema Speakers' started by mycool, Sep 17, 2005.
  1. mycool
    mycool
    Dec 28, 2004
    9
    Bedford
    I have some relatively old Kef Coda speakers which seem to have stopped working.
    I had a party recently and connected the Kefs up to my decks along with a pair of Jamo 120s. All was fine as volume rose until the Kefs started to crackle a bit with the bass. I reduced the volume so the did not distort and all seemed fine. Until today that is when i disonnected my decks and Jamos and tried to watch tv. The Kefs now only output via the tweeter and the larger (bass??) cone does not move or produce any sound.
    2 questions:
    a) Are the bass cones / drivers knackered?
    b) if so can the be repaired or is it a dustbin job?
    Please help as telly / music with no bass is rubbish!
    thanks
    Mycool
  2. KoThreads
    KoThreads
    Jan 18, 2005
    2,978
    +164
    My Coda 8's did this about 4 years ago. At that time I phoned Kef and they repaired them. It was only the bass drivers they replaced.
    As the guarantee had run out I was surprised that I only had to pay to send them and there was no other charge.
    I still have them as speakers in my spare room. Kef never told me what had gone wrong with them and it's never happened again.
  3. mycool
    mycool
    Dec 28, 2004
    9
    Bedford
    Where did you send them?
    Did you just get the Kef service centre number off the website?
  4. KoThreads
    KoThreads
    Jan 18, 2005
    2,978
    +164
    No I phoned a number on the instruction sheet.
    I don't know about now though as I believe they were taken over a couple of years ago.
  5. RSD123
    RSD123
    Even if the speakers are not under warranty you can probably replace the drivers (both, beacause they're mirror-imaged) I have a pair of Kef 105.2 's that i've never had to replace the drivers, but I know they still make them (and they're over 20 years old!). :D
