Help ive lost optical output on my compacks DVD! !!
Discussion in 'Blu-ray & DVD Players & Recorders' started by newstuart, Mar 19, 2005.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,807
    Northumberland
    +84
    I have a COMPACKS DVD5000 player which I unpluged my optical digital lead from to use with my playstation. Ive just reconected it but the DVD seems t give no output through it now ?? Ive checked in the menu and its still set to output so im somewhat stumped. any suggestions
  2. newstuart
    newstuart
    Apr 22, 2004
    1,807
    Northumberland
    +84
    ANYONE ???? Really dont want to have to buy a new player
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    If that's really all you did, ie. unplug and then re-plug, the only this that occurs to me would seem to be a faulty connector. Are you seeing a red light coming from it? When it should be outputting an audio stream?
  4. newstuart
    newstuart
    Apr 22, 2004
    1,807
    Northumberland
    +84
    Yep thats all I did, The red light still comes out of it to which is the strabge part. Ive since bought a new lead and tried that with no joy either
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Very weird, 'fraid I know nothing of your player so can't make any suggestions. :(
  6. newstuart
    newstuart
    Apr 22, 2004
    1,807
    Northumberland
    +84
    thanks for the input guys,
    Ive just tried it with the coax output rather than the optical and it works! how odd but at least its working so ill just run it from that instead
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Coax is often preferred over optical as long as you have decent quality cable.
