Help! Is the LC26GA4E VESA wall mount compliant, if so which standards?
Discussion in 'Home Cinema Buying & Building' started by calvinhobbes, Nov 30, 2004.
  1. calvinhobbes
    calvinhobbes
    :lease:
    Hi all
    Have my LC26GA4E arriving in a couple of days and I need a simple flat wall mount for it - does anyone know what the VESA settings are and if so where are good places I can buy a compliant simple mount?
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    It says on the manual 100mm so I suppose that would be VESA 100 then.
  3. alscds
    alscds
    yes it is call sharp in manchester 01612052222 they will send you one of theirs or look on their website
  4. calvinhobbes
    calvinhobbes
    Couldn't find any reference in the manual to 100mm or VESA, and sharp manchester are being unhelpful with telling me what non-sharp products would fit!
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    One of the guys bought a VESA 200 for the 32GA4E he bought. The manual doesn't say it is VESA compliant but looking at the bolt holes in the diagram, there wouldn't be a problem.
  6. alscds
    alscds
    sharp always say there products are standard veesa fitment
  7. calvinhobbes
    calvinhobbes
    Sorry, but can't find any info on the bolts in the diagram. Are you sure VESA 100mm would work or do i need 200mm?
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
