Help! Is my Humax Foxsat HDR as Dead as the Proverbial Parrot?
Geoff_W
It looks as though my 13 y.o. Humax Foxsat HDR has finally bitten the dust. It was working fine first thing this morning, but I brought it out of standby at lunchtime and it just hangs on the Custom Firmware 4.1.3 loading message. Having powered it down a few times I noticed that the Boot message doesn't appear before the CF message.
So far I have tried unplugging it from the mains and leaving it for at least 10 minutes (several times), but nothing makes any difference. Is there anything else I could try?
I note that Humax are currently offering the Aura with £50 off, so that might be my best option if all else fails.
dts
Unfortunately nothing lasts forever...it could be a hard drive issue...so maybe treat yourself to a new one.
REPASSAC
I would guess that it is a hard drive issue. Try disconnecting the hard drive. If it is that it should them boot. It that works then I suggest deleting all partitions on the disk in a PC or PC caddy and returning it to the Foxsat for reinitialisation.
Geoff_W
Thanks @dts and @REPASSAC
I put a USB pen into the front port with the Firmware on it but, whilst it now said "Boot" on the display and then "Custom Firmware 4.1.3", it still wouldn't start up. I then disconnected the HDD but no improvement. I've now removed the HDD and will fit it into a caddy to see if Windows 10 can read it.
However, I've taken the decision to order a 2Tb Aura from Humax, taking advantage of the £50 price reduction. So a bit of a learning curve ahead for me.
dts
Are you using freeview or freesat? I believe that the aura box is for freeview and not freesat...its a cracking box though.
Geoff_W
@dts Yes, I know the Aura is a Freeview box, I'm happy to change from Freesat, and I couldn't find many Freesat alternatives to my defunct HDR.
