Help installing an Hitachi 400GB drive please
Discussion in 'Computer Components' started by witters, Apr 23, 2007.
  1. witters
    witters
    Jul 13, 2000
    12,765
    Yorkshire
    +302
    I bought this IDE drive today and installed and formatted it. Problem is that more often than not I get a blue screen when I try to access it. If I remove the drive the problem goes away.
    I'm using it as a slave music storage drive only.
    Any ideas please?
  2. madman1178
    madman1178
    Dec 2, 2006
    198
    +9
    what error message do you get on the blue screen
  3. witters
    witters
    Jul 13, 2000
    12,765
    Yorkshire
    +302
    The usual one with the 0X0000000A, 0X00000019, 0X00000002, 0X00000000, 0X804EB977
    although some of these change each time.
  4. madman1178
    madman1178
    Dec 2, 2006
    198
    +9
    Might seem like a daft question, but have you tried typing the error message into google and seeing what it brings up?
    You could also try downloading a diagnostics program and running a check in safe mode.
    Was it a new drive, or second hand?
  5. witters
    witters
    Jul 13, 2000
    12,765
    Yorkshire
    +302
    Not daft at all. Tried all the above. I've just removed all the jumpers from the drive and it seems better. It's a new drive.
  6. madman1178
    madman1178
    Dec 2, 2006
    198
    +9
    That would have been my next question.
    Make sure the jumpers are in the slave possition.
    If you still have problems, take it back.
  7. Stiggy
    Stiggy
    Dec 7, 2004
    6,726
    Sandy Heath
    +1,043
    IDE? SATA? What are the details of your system? Have you changed anything else?
    I can't quickly think of something that would cause a bluescreen. Have you removed another drive that contained your paging file?
  8. Naqv
    Naqv
    Oct 15, 2006
    3,645
    Birmingham
    +355
    What have you formatted it as? FAT32 or NTFS and which operating system are you using?
  9. witters
    witters
    Jul 13, 2000
    12,765
    Yorkshire
    +302
    Formatted NTFS on Windows XP.
